NSRT4. Car wont start.
Got my i2010 today. Hooked it up to the PC ran the update. I then hooked it up to the car loaded the 91 tune which seemed to go fine. The car now wont start and when i try to go into the tune menu it tells me my car isnt supported and get updates from PC. When I try to update it via the PC it says no updates are available. Please help..
Re: NSRT4. Car wont start.
Hi ENZO, I ordered one for my 2013 SXT Challenger. Should be here by tomorrow, But will do the install Friday. Man I better not have any problems with mine. I figured with the update things should go smoothly. I was told by Sean at Hemifever that Diablo sport ironed out the issue with the flashing crashing our system. What type of Vehicle are you using this on if you dont mind me asking? Happy New Year......
It's a 2005 SRT4. I'm sure that tech support will get me fixed up.
please post the info.xml file from the intune drive pr give us a call with the tool powered up in the car.
Will do as soon as i get home from work.
Here it is. Calling in as soon as its powered up in the vehicle.
I did the update and registration no problem. Will attempt the install Friday. Best to you....
Called up tech support and mike got me all squared away. Really liking the tune, not sure the actual HP but the butt dyno is sure happy.
