Jeep GC 2007 5.7 Ltd (not supported?)
Hi,
Just bought a new i2010 and got this delivered in Australia. Plugged into my laptop and it went through the update cycle. Took it and plugged it into the car, pushed Tune Vehicle and it says vehicle not supported. Not sure what I need to do?
Jeep Grand Cherokee 2007 5.7 Limited
Re: Jeep GC 2007 5.7 Ltd (not supported?)
Info file as attached
unfortunately we do not have support for the export Cherokee calibrations.
You do not publish this anywhere, so I have just wasted $400
You could ask http://www.hemifevertuning.com/ to create a custom tune.
Surely the i2010 device would have to be able to communicate with the car in the first instance to be able to do this?
Hello, I also do not live in USA, got i2 does not support Jeep Grand Cherokee 5.7 Hemi lights only function "data loggin", as though I bought was a lot of determination.
wasted $400, I tried to use to contact diablo did not get a complete answer
I would be glad to receive updates 06-10 Jeep Grand Cherokee 5.7 Hemi.
or would like to get your money back
Is the ECM computer the same between US and Export, but contains different software?
yes same pcm, different software.
I have seen people figure out how to get US cals into the pcm to make it supported.
My 2014 RAM Laramie is an Export vehicle as stated on the sticker - I'm in Germany.
I could tune my truck without a problem - just logging is still a problem (but not only on my verhicle
I actually have a working ECU from a US 2005 WK 5.7 Hemi in my shipment coming from Dubai to Australia. Can I swap this with the existing ECU in the export 2007 WH 5.7 Hemi and expect this to work?
