2015 Dodge Charger R/T tuner feedback
Hello this is my 1st post here, i own a 2015 Dodge Charger R/T with the Road and Track Pac and i want to pull the trigger and get my tuner + pcm but i wanted to hear some feedback and see the gains aswell. Thanks in advance.
redvapor01
Re: 2015 Dodge Charger R/T tuner feedback
Not exact setup but 2015 srt Jeep with supercharger kit. Did buy PCM and Tuner and the tuner wont communicate with the PCM and they are trying to fix now. I can tell you when I ordered the PCM and it came in it installed and worked without error. Hope this helps
Any feedback/info works for me. Thanks for letting me know about the pcm work with no problem. Hopefully more people will chime in to let me know how it performs on the plataform im looking for.
I have the charger RT with the road and track package. I have the I2 and PCM. I currently use the 93 octane tune with deactivated MDS, throttle response is at 100%, I also have fuel mixture at 7% rich. ( I was told I dont need to change the mixture on this car so dont do that because of this post) The only mod I have is my own version of a short Ram intake using a large spectra air filter and a 6 inch tube attached to the factory tubing where the air box was. I have to say the tune without a doubt makes the car much more fun to drive. my 0-60 times are consistently 5.2, 5.3 and sometimes I will get a 5.0. ( .02-.03 better) I would have to say if I had sticky tires I might be able to do better. There are way too many variables in a 0-60 to really base the the tuner on that alone. I am very happy with the tuner, I have had it since end of November. Good luck.
Thanks, that does help. You are using the canned tune right?johnvito wrote:I have the charger RT with the road and track package. I have the I2 and PCM. I currently use the 93 octane tune with deactivated MDS, throttle response is at 100%, I also have fuel mixture at 7% rich. ( I was told I dont need to change the mixture on this car so dont do that because of this post) The only mod I have is my own version of a short Ram intake using a large spectra air filter and a 6 inch tube attached to the factory tubing where the air box was. I have to say the tune without a doubt makes the car much more fun to drive. my 0-60 times are consistently 5.2, 5.3 and sometimes I will get a 5.0. ( .02-.03 better) I would have to say if I had sticky tires I might be able to do better. There are way too many variables in a 0-60 to really base the the tuner on that alone. I am very happy with the tuner, I have had it since end of November. Good luck.
Yes it's the canned tune. The tuner allows tweeking to the canned tune. Good luck to
Thank you!johnvito wrote:Yes it's the canned tune. The tuner allows tweeking to the canned tune. Good luck to
