Cannot update until registered, but can't register
Endo
Post by Endo »
Hello,
I was updating my inTune today and something must have gone wrong because the GM tune database is missing. I tried to update manually, but it says "This intune cannot be updated until it is registered". I then tried installing the registration.itf file I found on the forums. The inTune reboots after I move the file, but it still isn't registered. Any ideas? Attached is my info.xml.
info.xml
(2.08 KiB) Downloaded 593 times
Re: Cannot update until registered, but can't register
save this to the intune drive.
registration.itf
(377 Bytes) Downloaded 578 times
Endo
Post by Endo »
mikel wrote:save this to the intune drive.
Same problem with that file. I move it to the inTune drive and the inTune reboots, but it still says it's not registered.
I emailed you a file to use.
Endo
Post by Endo »
Thanks, Mike. It's working now.
rm1515
Post by rm1515 »
I am having this same issue.
chrisfischer7918
Post by chrisfischer7918 »
I'm having the same issue my email is [email protected]
info.xml
(1.68 KiB) Downloaded 554 times
panther20
Post by panther20 »
My intune will not let me register either. I've tried many times, here is my info
info.xml
(2.35 KiB) Downloaded 502 times
I emailed both of you a registration file.
Gardnen3
Post by Gardnen3 »
I have the same problem. Once it reboots it says it can't update until its registered.
custommasters
Post by custommasters »
Hi . I have the same problem . I tried to update manually, but it says "This intune cannot be updated until it is registered". I then tried installing the registration.itf file I found on the forums. Now i have a new message "A calibration update has been detected for an unknown vehicle.Please contact Diablosport for further information" And i have enouther error "Tool oem is missing" Please help me.I don't know what to do.
IMG_1700 (1).JPG (1.52 MiB) Viewed 11199 times
info.xml
(557 Bytes) Downloaded 434 times
yeah you can't use someone elses registration file man.. have to wait for one to be created for yours..
this one will work for anyone.
_registration.itf
(387 Bytes) Downloaded 507 times
custommasters
tool oem is missing. nothing is changed...... Last month i changed my PCM in jeep .Unplugged my diablo sport from my old pcm . And now i can not tune my new PCM in my car . But scan tool is aviable . Diablo writes my that my vin number needs a calibration and not supported. My car is jeep grand cherokee str8 2006 year 6.1 hemi
gsamford4818
Post by gsamford4818 »
I'm having the same issue as most people here. I can't get my I-1000 to update and I have tried using the registration file that has been used here many times. Every time it reboots it says it can't be updated until it is registered.
My email is [email protected]
info.xml
Here is my xml file
(640 Bytes) Downloaded 459 times
