Intune Not Updating nor recognizing my car
n3xxi
Post by n3xxi »
MY intune just recently starting acting crazy. When trying to adjust parameters on my car (srt4 neon) the intune scans for car and says that car is not supported. So i figured i needed to update it. When i try to update the intune it continually takes me to the registration page.
<?xml version="1.0"?>
-<tool_info>
<main svn="8176" sw_rev="1r04e" full_version="InTune-1r04e 02/12/2015 08:55:43 AM"/>
<registration status="0" sn="J22F526-4"/>
<cal_id PCM="05029415AH"/>
<restore bc="22" vin="1B3AS66S44D596577" id="0"/>
<system_db vin="1r01e" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" tune="missing" mfr="DCX"/>
<db pid="1r01b" tune="1r01w" mfr="FORD"/>
<db pid="1r01a" tune="1r02l" mfr="GM"/>
-<license tuned="1" avail="1">
<tuned vin="1B3AS66S44D596577"/>
</license>
<updates count="6"/>
<oem tool_oem="DIABLO"/>
info.xml
(3.54 KiB) Downloaded 338 times
Re: Intune Not Updating nor recognizing my car
register it then update it....then it will work.
n3xxi
Post by n3xxi »
Yea. Every time I go to register it. It says that it is successfully registered then when I go back to the updater it takes me back to the registration page.
I emailed you a file.
ravenfaust
Post by ravenfaust »
having same issue...
-<tool_info>
<main svn="9115" sw_rev="1r04j" full_version="InTune-1r04j 03/14/2016 10:51:37 AM"/>
<registration status="1" sn="JNW2EE2-6"/>
<cal_id CM1="68239158AC" PCM="68228440AC"/>
<restore bc="48" vin="2C3CDZBT2FH709728" id="0"/>
<system_db vin="1r01g" dtc="1r01a" info="1r01b"/>
<db pid="1r01b" mfr="FORD"/>
<db pid="1r01a" mfr="GM"/>
<tuned vin="2C3CDZBT2FH709728"/>
</license>
<updates count="14"/>
<oem tool_oem="DIABLODCX"/>
<reg reg="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"/>
</tool_info>
