Failed Again
dizzyphil
Failed Again
Post by dizzyphil »
So. About 6 months ago I teetered between Bully Dog and InTune. Well.... thinking I should have gone Bully Dog like I have in the past.
I had to send my InTune and PCM back to have re-written because my InTune shut down my truck. Overnight everything and got it back in a few days, installed PCM and truck started and I was fine.
Today - big mistake. I hadn't touched the InTune since and was working on my Ram today - changed oil, flushed tranny and new filter, flushed cooling system, rotated tires, new brakes, and new gear oil in the back. My buddy up the street came down and said, when you going to get the balls to install the Diablo Tune? So, I said..... okay, let's do it. Took it inside, hooked it up to the laptop, downloaded all the new files - went to the truck.
Wrong fucking answer. InTune went into recovery mode
AGAIN
And again, truck won't start.
99SSragtop
Re: Failed Again
Post by 99SSragtop »
What does your radio screen say ?
1999 SS Camaro, A4, 01 LS6 Cam, BBK Shorty Headers, Free Mods.
2009 G8GT Basically stock but intune.
dizzyphil
Re: Failed Again
Post by dizzyphil »
done this rodeo before..... only three items not stock on the truck that are electrical and all the fuses were pulled before we started.
dizzyphil
Re: Failed Again
Post by dizzyphil »
Here's the file......
info.xml
(1.89 KiB) Downloaded 201 times
dizzyphil
Re: Failed Again
Post by dizzyphil »
.drg files
PCM_56029218AH_Backup.drg
(50.12 KiB) Downloaded 175 times
PCM_56029218AH_LastTuneWritten.drg
(50.12 KiB) Downloaded 186 times
TCM_56029225AEB_Backup.drg
(123.44 KiB) Downloaded 157 times
TCM_56029225AEB_LastTuneWritten.drg
(123.45 KiB) Downloaded 173 times
99SSragtop
Re: Failed Again
My intune froze and basically every thing locked up car wouldn't start, couldn't get key out , lights on radio said computer mismatch or some thing like that. So i disconnected the positive bat cable from the ecm under the hood. All back to normal. Hooked the intune up and set everything back to stock. I haven't tried reloading a tune yet but may try later this week. Hope it doesn't freeze again.
dizzyphil
Re: Failed Again
Post by dizzyphil »
not that easy for others. this is the second time i tried the intune - second time it has junked my truck
dizzy
