Interested in getting an i2 but I don't see very many adjustable parameters. The power wagon is pretty much just a 3/4 ton wrangler rubicon. it has locking front and rear diffs and sway bar disconnect. Below is the list of parameters I would like to have for my truck. Note some are already available and a lot of people are looking for these options. What is the ETA for adding these?
- TPMS threshold adjustment
- locker bypass. Lock differentials in all modes
- sway bar disconnect bypass. sway bar disable
- change tire size
- change gear ratios
- MDS disable, Cylinder deactivation
- Fog light enable
2015 Power Wagon
Re: 2015 Power Wagon
So no response from Diablo on this?
these are difficult to add and will take some time, but we are looking into it.
When you say you are looking into it what does that mean? Is it being worked on? what is the ETA? Or does we're looking into it just mean go away? I appreciate real answers without BS.
I do not have any ETA. Its a lot of work to implement these features and will need to be weighed against other current and planned projects.
If you are really looking at it and weighing it against other projects you should be able to give an ETA. I believe people have been requesting support for these features since 2011 so what's the hold up?
So are you still "looking into it"? What's the update on this? Is it in the works yet?
