in tune 2 not working
ramsun
Post by ramsun »
hi just purchased a dx 2000 to replace adx 1000 took it out of the box up dated and went to tune my 2012 ram 5.7 the tool saved original tune i choose the 87 oct. advanced tune the tool wrote the tune and i adjusted the paremeters and the tool failed to install the tune massage failed to to install and went into (recovery )and advice to re install original back up i did and re tried to install a different tune this time a massage (tool on recovery mode n and failed to write the tune i am back to original tune very disappointed i hope you can help thanks Ray
Re: in tune 2 not working
please post the info.xml file from the i2 drive.
ramsun
Post by ramsun »
mike l can not post file other options
ramsun
Post by ramsun »
mike l did you get my fax w. tie file my computer will not import file please let me know if you can help ? if not i will return the tool
fax?
Please attach it here, use the upload attachment option at the bottom of the page when you make your reply.
ramsun
Post by ramsun »
mike l will not work i will fax again ok is your fax no, 561 431 0429
you can't FAX a file man.. you have to post up the actual file from the tool so it can be checked and possibly updated if needed...
you have to copy the file from the intune to your computer.. then post a reply here and attach the file from your computer into your post reply.
