I am doing a 6.0l LS swap in a '95 Jeep Cherokee I am building. I plan on using a TH400 trans instead of the newer 4sp stuff and a stock GM ECU. The question I have is, will the Trinity be able to be programmed for not using the electric trans and not throw codes? Since this is an off road trail/street rig I do not plan on doing much to the engine except possible a RV type camshaft. BTW this is a manual TB engine.
Mike
Trinity in a LS swap question.
Re: Trinity in a LS swap question.
Should be fine if you start with a manual cal on the PCM.
Thanks Mikel, I thought that maybe the case. I got the factory GM ecu with the engine just trying to finalize how I want to manage the system.
