Cannot register Intune
madamian
Re: Cannot register Intune
Post by madamian »
I cant get my i1000dcx to register online either
was working fine last week.
First it said it couldn't recognize vehicle... so I plugged it in and updated no prob...
then back in the car it said I need a pcm calibration.... so I plugged it in and it wouldn't upgrade
so I brought it back to the car and it said it needed pcm calibration again...
brought it back upstairs tried to upgrade.. said I needed it register the intune.....
it wont even let me restore my vehicle to stock tune even though it says it has the file still located on the intune..???
please help me out. I put in a 180 tstat and a 3;91 rear end and I hope nothing had messed with the values in the car...
thanks.
Damian.
info.xml
(2.03 KiB) Downloaded 878 times
garrett
Site Admin
Post by garrett »
i have replied to your email with your registration file. Thanks.
chandler74
Post by chandler74 »
Cant get intune to register. just started having this problem. Here's my info, any help would be great, thanks.
info.xml
(2.12 KiB) Downloaded 788 times
chandler74 wrote:Cant get intune to register. just started having this problem. Here's my info, any help would be great, thanks.
I emailed you a file.
chandler74
thanks
meibierisneddepat
Post by meibierisneddepat »
Hi,
Can you please provide me with a registration file. .xml attached. Thanks.
info.xml
(3.94 KiB) Downloaded 854 times
Last edited by meibierisneddepat on Thu Mar 10, 2016 2:10 pm, edited 1 time in total.
cgreen
Post by cgreen »
Hello,
Could you please provide me with a registration file?
info.xml attached
Thanks!
info.xml
(2.29 KiB) Downloaded 792 times
emailed both of you.
mike1088
Post by mike1088 »
hey i got the same problem here! can you fix it plz!! :)
Mike
info.xml
(2.08 KiB) Downloaded 772 times
gtpimp
Post by gtpimp »
Same problem. Here's my file. email is [email protected]
Thank you.
info.xml
(2.35 KiB) Downloaded 887 times
emailed you both a file, save to the intune drive and it will be registered.
ChristinaRTClassic
Post by ChristinaRTClassic »
Hi. I am basically giving my Intune 1000 to a friend who has a 2010 Dodge Challenger RT. I sold my 2009 RT (after releasing the car from the tuner) and the tuner has been stuck on my shelf for a year. It took me 2 hours to update the tuner to the latest and greatest (no small thank you's to Windows 10). However, it still says my friends 2010 is not supported. I am assuming that I need to re-register my DC1000? I have attached my info.xml file.
info.xml
(1.93 KiB) Downloaded 770 times
nellens78
Post by nellens78 »
Also after I register my intune it shows successful but then when I hook it to a computer it says not able to update until registered. I will attach my file.
My email is
info.xml
(2.02 KiB) Downloaded 783 times
Wrangler4Life
Post by Wrangler4Life »
Hi Team,
I am Unable to register and update my I-1000 SP-100 Intune. Please see attached xml file.
If I try and drag and drop files into the tunes folder I get the message you need to register first etc.. I can see all the files listed in the CD drive and every time I run the InTune.exe It takes me to https://www.diablosport.com/register.ht ... GXFL561616
Any help with getting my tuner registered so I can update the tuner for my new ECU would be much appreciated
my email address is [email protected]
CD File
CD File
info.xml
xml file
(2.17 KiB) Downloaded 785 times
ChristinaRTClassic wrote:Hi. I am basically giving my Intune 1000 to a friend who has a 2010 Dodge Challenger RT. I sold my 2009 RT (after releasing the car from the tuner) and the tuner has been stuck on my shelf for a year. It took me 2 hours to update the tuner to the latest and greatest (no small thank you's to Windows 10). However, it still says my friends 2010 is not supported. I am assuming that I need to re-register my DC1000? I have attached my info.xml file.
this tool is good to go.
