02 sensor delete
Rmejia
02 sensor delete
Post by Rmejia »
I have an 05 silverado that has short tube headers, intake, and flowmaster. I was told that with a diablo sport tune i could have the 02 sensors "turned off" i am not worried about smog at all. Is this possible? I also want to try to get a custom tune from one of the guys at diablo sport
Badgasr
Re: 02 sensor delete
Post by Badgasr »
Does your truck have pre cats and post cat converters? If so only the post cat sensors can be shut off.
you can not disable codes with the tool.. you'd need to get a custom tune done in order to have codes disabled.
Rmejia
Post by Rmejia »
06MonteSS wrote:you can not disable codes with the tool.. you'd need to get a custom tune done in order to have codes disabled.
So how would i go about this? Should i remove the cats, let the code pop up then have the custom tune written? Or could i have the tune written then have my exhaust redone??
2005 silverado 5.3
Intake
Headers
37" tires
4:56 gears
Currently have the 91 octane diablo tune
www.diablewtune.com
and can also email me directly at: diablo DOT help AT gmail DOT com - send me all of your truck info - year, model, engine, mods that are done to it, etc. and I can email you all the info about the custom tuning, the process, etc.
Rmejia
Post by Rmejia »
06MonteSS wrote:http://www.diablewtune.com
Thank you very much, ill get that sent asap
