2016 scat 6.4 installed tuner
maxboosteric
Got everything today, updated it and installed. Very disappointed as of now as all I can change is gears, tire size and speed limit. Both tunes on 93 feel the same as my stock tazer track mode. Does the tune change Every setting from default to track? Did you raise shift points? Should I run the quick tune 93 which lets me make the 3 changes only. The other tunes called 91 and Diablo don't let me modify anything. I can't add no timing????? I did have 0 knock retard which means I wanted to add some. Has anyone figured out the trans firmness yet. mine needs to shift lot harder.
maxboosteric
Re: 2016 scat 6.4 installed tuner
I was very happy with my 06 srt8 tune but Johan did it.
you can adjust anything you desire, select the tune then choose the modify parameter option and it will let you adjust WOT spark and fuel, rev and speed limits, etc...
maxboosteric
That's what I am told but mine is blank! Nothing ever comes up on that screen. Maybe I updated it wrong or something.mikel wrote:you can adjust anything you desire, select the tune then choose the modify parameter option and it will let you adjust WOT spark and fuel, rev and speed limits, etc...
is the tool up to date?
maxboosteric
I just updated it. Pretty easy to do it does it basically on its own.
I will run the updater again
maxboosteric
Ran updater again and I still have nothing to adjust. I tried the 91 tune and it was the same. What can I do now.
Post the "info" file from your intune drive please.
Insert Clever comment here...
maxboosteric
Okay give me a day I am tied up at work
maxboosteric
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="1FSY7L1O28"/>
-<applications count="5">
<application rev="2r01g" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01c" name="gui"/>
<application rev="2r01b" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01c" vin="2r01g" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" tune="2r01c" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
<last-connected vin="2C3CDXGJ3GH146153" mfr="DCX" calid="05035895AC"/>
<last-connected calid="05035473AC"/>
-<licenses tuned="1" available="1">
<license vin="2C3CDXGJ3GH146153" mfr="DCX" PCM="05035895AC"/>
</licenses>
<reg reg="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"/>
</tool_info>
-<tool_info>
</applications>
</databases>
</licenses>
</tool_info>
maxboosteric
Anything?
Yep going to try and have you a new build tomorrow.
maxboosteric
New tuner/computer or new files?
I have same problem. The advance menu does not appear. Everything else is blank. please help. Thanks.
