i2 Update Won't Open
When I hook it up to the USB on the computer and run the updater, the page won't load. It tells me to refresh the page and when I do, it tells me the page cannot be displayed and to make sure I have the correct address.
Re: i2 Update Won't Open
can you post the info.xml file from the i2 drive here please?
file:///E:/info.xml
Here it is
save this to the root of the i2 drive and let it reboot then try opening the updater again please.
It works Thank you. I know this is pertinent to the specific forum, but how do i data log? I've tried multiple times where I have a custom tune, and when I go to add parameters, I select what I need and tell it to go back and it will ask if I'd like to save selection. I go to record and there are literally no parameters listed. I don't even have the option to delete parameters if I want to, which tells me they weren't actually selected in the first place.
