MDS will not turn off and on
I just got this tuner and the car a few months ago. 05 300c 5.7 stock. Set it to the 91 tune turned off mds then an asterisk shows only on the mds on only. even if i turn mds back on and apply the tune over, the (*) never leaves from mds on. Can someone help me out please. I uploaded the info file from the the tune i just did today. Also i get the u0100 ever now and then.
Re: MDS will not turn off and on
You won't get an answer. This is the same issue I was having. The tech manager dismissed it. Fed me some line about it being on and to just ignore the *. I just came back in the hopes that they would admit that there is a problem, but I was right to assume I would be ignored. Im probably going to sell this tuner and go with a different brand. It's a shame that I've bought 3 tuners from Diablo since 2009 and it sucks that they leave some people high and dry. Good luck though.
Damn bro thanks for the heads up. Imho i think its off and the only way to turn it back on is to clear all parameters or revert back to stock. But the mds was truely my only reason i bought this tuner.
the astterisk is a display issue, do you not notice MDS off when driving around?Aktive16 wrote:I just got this tuner and the car a few months ago. 05 300c 5.7 stock. Set it to the 91 tune turned off mds then an asterisk shows only on the mds on only. even if i turn mds back on and apply the tune over, the (*) never leaves from mds on. Can someone help me out please. I uploaded the info file from the the tune i just did today. Also i get the u0100 ever now and then.
please load the tune with mds off then post the tune files from the tunes folder here.
