When the dealership reprogramed some modules and made it to where the Trinty wouldn't apply any tune files. I called the office and they ran me through resetting the tool. I updated the tool with the newest update 1r13h. The tool used to have the 1r13c update. Now I have a new problem. Since I couldn't use the tool to "go back to factory" its stuck with the custom supercharger tune. I do have the original pcm file and custom tunes are both backed up on a flash drive.SojiaRaggs9000 wrote:On my 2008 Chrysler 300 with a Supercharged 3.5L V6.... My DiabloSport Trinty is giving me error code message "(3) this tool is not licensed for use with this vehicle." Settings shows my vehicles vin# and last tune written was an "+ quick adjustment". Original pcm file and custom tunes are both backed up on a flash drive. Everything else seems to work fine I just can't edit or re apply any tunes.
What do I need to do to get it working again. Also as a side question..... is there a way to leave the OBD connector for the trinity plugged in without it draining my battery?
If I use the usb at the PC...... The tool powers up and asks for the type of vehicle. It finishes setting up and resets. After a few seconds it will boot back up and then freeze. Using the OBD connector it setup the vehicle type and restarts. Once it restarts it pops up the disclaimer page and freezes. Using the USB I did get it to go the info section and it showed unmarried. I can't finish marring the tool... it just freezes. I even tried loading in the supercharger tune using my old pcm back up.... being that its not married I cant add any files to the tool because it freezes.
What can be done? Advise?
