2016 F150 2.7 EB Cal ID help
Srd5711
Post by Srd5711 »
I plugged in my in tune i1000 and let the program run its course then I tried to tune the truck and got a "vin needs an update" message and then when I hooked it back up to my pic I got this mess(image attached)
Please let me know what to do next.
sohfast94
Re: 2016 F150 2.7 EB Cal ID help
Post by sohfast94 »
For whatever reason this file is not on the ford site. Could you possibly pop the little black cover off the top of the pcm case in the engine bay? It's on the passenger side firewall right at the top. The plastic cover is super easy and the label will be right below it. If you could post a pic of the label that would be really helpful an dI'll add it right away. No idea why it's not on the site.
Insert Clever comment here...
Srd5711
Post by Srd5711 »
SohFast,
Is this what you need?
Srd5711
Post by Srd5711 »
Heres my info file from the intune as well
info.xml
(6.74 KiB) Downloaded 153 times
Srd5711
Post by Srd5711 »
Any news?
sohfast94
Post by sohfast94 »
I think we've already helped you as I recognize your calid, in case we haven't here is the update.
Also FYI: This is an i2 ITF as you posted an info file from and i2.
FORD_TUNES-2t02hk.ITF
(16.48 MiB) Downloaded 169 times
