2005 Jeep Turbo 4.5 Stroker
i'm building a turbo stroker but i haven't figured out how to manage the programming. will the inTune work for my application?
Re: 2005 Jeep Turbo 4.5 Stroker
with a customtune from a cmr tuner, yes
how can i find a base tune for my situation? i now may be doing a supercharger but i dont think that changes the programming issue.
I wonder if the custom tune I got from Banks would work for a base tune. My engine is stock running 7lbs boost no intercooler.
superchargers will need different maps as they put more load on the engine, but it may run ok out of boost if the map and injectors are the same.
well its official its going to be a supercharged 4.6L stroker.
i will be running an Eaton M112 and should see boost at idle if not just off idle. how can i develop a base tune? because this is my daily driver i cant really afford to take days to trouble shoot tuning.
you really ave to work with a cmr tuner and will likely need some time dialing it in.
i understand i'll have to do some tuning and tweaking to have a final product...... but where do i get my starting point? obviously my stock tune wont fly.mikel wrote:you really ave to work with a cmr tuner and will likely need some time dialing it in.
work with a tune who can provide you a base tune via email.
do you have a list of tuners who can help me? my engine is almost ready to roll but if i dont have a tune i wont go anywhere.
btw i'm running a blower instead of a turbo if that helps.
