Intune TM settings 2007 nnbs 5.3 l 4L60E
uswkem51
Post by uswkem51 »
I am wanting to reduce the TM on my truck by about 50%. My truck has the 4L60E.
I know on the 6-speeds it's either ON or OFF. With the 4-speed, is there a percentage when within the programmer or is it a series of negative and positive numbers. What do I need to set it at to reduce TM by about half? Right now I just have AFM turned off and want to reduce TM a little. What kind of effect will that have on the drivability? I don't run the truck hard either but would like a little more responsiveness.
For the canned 87-Octane tune, what parameters are adjusted? Is TM fully removed, 50%, 75%, etc?
For my truck (2007 Silverado 5.3L w/ 4L60E) is there TM on both the motor and transmission or just the transmission?
Mossyoakglock
Re: Intune TM settings 2007 nnbs 5.3 l 4L60E
Post by Mossyoakglock »
Bumping this one.
I am want to know this same thing for my '08 Silverado w/ 4L60E.
2008 Chevrolet Silverado
5.3L w/ 4L60E
2.5" level w/ 275/60R20 BFG KO2
Airaid MIT
Vette Servo
tm on the engine is removed, tm on the tcm is only left on for upshift abuse mode, as turning that off iften leads to sloppy shift feel on the trucks.
Mossyoakglock
What about if wanting to run the modified stock tune and just reduce TM?
What setting should we put on the intune if we want to remove roughly 50% of the TM? Right now I have just AFM turned off with Modified Stock Tune. I also want to reduce TM by about 50%. What setting does it need to be at?
5.3L w/ 4L60E
Airaid MIT
Vette Servo
