Parameter Setting
Junkman63
Parameter Setting
Post by Junkman63 »
i just got my tuner a couple of days ago load the 91 octane on my 2013 Ram 1500, after a update first. but my problem is i only see quick adjust parameters for Tire size and Traction control. i also think i performed a data log and i tried to view it on my computer with download software from the website and am having problems.
Re: Parameter Setting
thats what you would see in the quick adjust menu, but the other params are in the modify parameter menu after you choose a tune.'
Junkman63
Post by Junkman63 »
Thanks for your reply i did a restore and chose the diablosport tune and i found the other parameters, i changed the tires to a 30 inch which is 275/50/R20 and up the speed limiter to 180, can you recommend some more parameters i might could adjust that will benefit my 2013 ram daily driver, i also boosted the throttle 6% should i go higher on the throttle boost.
