when will I2020 work on sho
toolman7963
Post by toolman7963 »
I have been in two forums with no responce. my tuner says it does not know my calibration files attached I need help but am getting no where here
info.xml
(1.68 KiB) Downloaded 126 times
Re: when will I2020 work on sho
we're looking into this.
sohfast94
Post by sohfast94 »
It's fixed toolman.
Insert Clever comment here...
toolman7963
You are the best. It has a cold air intake and a corsa exhaust. With the tune now it sounds great. When it quits raining i will go play. Thanks again
toolman7963
It all works but removing the speed limiter. If you remove there is no throttle response idle only.
use the advanced tune menu to disable the speed limit, easy tune has a bug that sets the limiter to 0 mph hence the lack of throttle in drive.
