U7198 and the innovate LM-1. 02 camaro
boola1341
Post by boola1341 »
Is there a plug-in to some how hook the predator and the LM-1 together? The U7198 doesn't data log and the LM-1 does but the LM-1 doesn't show what rpm i'm at when showing the AFR. If it did that would help alot. Or is there a way that the predator can data log :?: My main question is can the 2 be hooked together as one? Sorry for so many questions here lately.
RE: U7198 and the innovate LM-1. 02 camaro
nope... your 7198 can not save logs...
you can view the real time data live on the predator screen while you drive though...
BUT - dunno if the Innovate plugin works like that... sounds like you need to be able to save logs, because they have a plugin for the software here... http://www.innovatemotorsports.com/products/diablo.php
sickREDsierra
Post by sickREDsierra »
well, your predator can only adjust PE settings in two main rpm incriments anyway..... so knowing what precise rpm you are at with the correlating A/FR wouldnt do you that much good......
i would just have a friend ride along and write down the real time data on the predator while you glance at your A/FR while at WOT.... or sit the DS in front of a handheld camera and record the data while you drive....if you can't do logging.
2007 Sierra, 370 C.I. , Custom CompCam, ProEdge 3600 converter, 4.11's with eaton LSD, Foose 20's, DynoTune Nitrous, Patriot CNC'd heads
sickREDsierra
edit----- is your lm-1 hooked up to an AFR gage, or are you just running it as a stand-alone and reading what it records?
boola1341
Post by boola1341 »
missed your response. I'm using the LM-1 as a stand alone
2002 A4 LS1 Camaro
Pacesetter Long tube with ory
Flowmaster Catback
3.73 gears with a Auburn differential
Slp air lid and msd wires with ngk tr55 plugs
Best time is 12.89@109 with a 2.0 60' on BFG Kdws street tires
Return to “Predator GM Gas”
