2005 srt4 adding boost and wot fuel
AndyX2
Post by AndyX2 »
I am currently logging and tuning my srt4 and am alittle confused by one thing. When i go to add wot fuel when i go towards "rich" the percentage goes negative but when I go towards "lean" it goes to a positive percentage. Which percentage is adding fuel? I assume its when I go towards rich but why is the percentage shown a negative number? Same with boost adding boost shows a negative percent while lowering boost shows positive? Its slightly confusing.
Intune i2 fully updated
Re: 2005 srt4 adding boost and wot fuel
going rich is adding fuel, you are commanding a lower AFR, hence the (-).
AndyX2
Post by AndyX2 »
Thank you Mike! That makes sense. Is the - percentage to add boost also the same concept?
SPLNeon
Post by SPLNeon »
Sorry to thread jack, but does the wot timing adjustments work this way as well? Like to add timing, you would put it to a negative selection?!
