Rev limiter stalling my car
dubairt84
Post by dubairt84 »
Hellooooooos
2015 Chally
RT plus
Mopar exhaust
Mopar CAI
HnR coilovers
HnR 30mm spacers
So going to try my luck and hopefully get an answer here.
Have a 2015 Chally RT plus
just installed the new PCM and intune yest.
Did the Diablo tune done (input tire size and without anyother changes to parametres) = Runs superb
Did the Diablo tune done (input tire size and changed throttle boost to 5%) = Runs awesome
Did the Diablo tune done (input tire size and changed throttle boost to 5% and MDS to off) = OH MY DAYS
Did the Diablo tune done (input tire size and changed throttle boost to 5% and MDS to off AND changed setting on rev limiter whilst idle and driving) = car at P or N = stalls (sounds like cam has been installed with no response from gas pedal) but when in D drives rly rly well without any knock or anything
Did the Diablo tune done (input tire size and only changed setting on rev limiter whilst idle and driving) = same thing - car no reponse from gas pedal = car at P or N = stalls (sounds like cam has been installed with no response from gas pedal) but when in D drives rly rly well without any knock or anything
maybe i have a faulty tuner or is there something i am doing wrong.
at present have left the car at = tire size and only throttle boost to 5%.
please advise. :lamer:
i want to squeeze as much as i can from this $1000 investment :evil_angel:
IG - Dubai_rt84 :evil_angel: :evil_angel: :evil_angel:
sohfast94
Re: Rev limiter stalling my car
Post by sohfast94 »
So let me get this straight, if you change either one of the rev limiters then this happens? Can you get a last tune written of when you have this change programmed to the vehicle? Just load the tune with the changes and then post the files from the tunes folder. (Also if this car is an auto it's not going to change the shift points)
Insert Clever comment here...
this is going to be an issue with the neutral limiter, likely setting it way too low, adjust the neutral limiter then post the tunes from the intune drive and we'll check it out.
dubairt84
Post by dubairt84 »
Hey guys
Really appreciate the replies.
Make some have more faith again on Diablo :)
Ok so the rev limiter is max at 600rpm. Is that normal ? Wouldn't it be 6000?
I have chbaged the rev limiter idle, neutral all to max still no change.
Right now riding on Diablo tune with 5% throttle boosters activated.
Car is auto
Please advise guys.
thats + 600 rpm over stock.
