2015 Wrangler Quick tune options
ducatidesmo
Post by ducatidesmo »
HI all,
Have an I2 and noticed the only thing that really works is changing the tiresize axle ratio, and enabling/disabling TPMS
I can't get Threshold to work for the life of me. at 28 psi and I have set that to 28PSI (understand the 5 above and below rule) but still throw a TPM error because the psi went below 30
Turning on front and Rear axles does nothing.
Disabling the swaybar does nothing as well.
Any hints? I did start with another tuner that did do all the stuff above on the fly.
-D
ducatidesmo
Re: 2015 Wrangler Quick tune options
Just wanted to see if there was any additional insights on this.
Thanks!
threshold have been difficult and we are still testing that.
Is this a Rubicon?
ducatidesmo
That's correct 2015 Rubicon.
I just realized that you have to ask that question cause someone with no lockers sure could say "it doesn't lockup the lockers!!" ... That's because you don't have lockers dummy..
Thanks for the heads up on the Threshold. I ask because I run around 28-30 pounds in the tire when I'm driving on the street as they are beadlocks... the system does not like when you go below 30 (5PSI below the set of 35 right... ) the it throws the check TPM system error until 1) you go above 35 PSI or 2) you unplug the battery.
I'll see if I can replicate this on a Jeep here.
lewis500
Post by lewis500 »
All mine says is Quick Tune. How come it doesn't show no downloaded tunes?
