Units Conversion
Units Conversion
Is there a way to convert the units to Metric?
Re: Units Conversion
yes, click on the gauge inthe edit menu and select change display units.
tech@diablosport.com
HI. I have a inTune i2 and for the life of me, I cannot figure out how to switch from metric to standard readings. Please help. Thank you
you can not change the units on the intune screen display... but when you open the log in the DataViewer, they will be in US standard...
I think I understand, correct me if i'm wrong. The unit itself is in metric, but when attached to the dataViewer, the info it is then converted to US standard, And, there is no way to change the units physical data display to US standard?06MonteSS wrote:you can not change the units on the intune screen display... but when you open the log in the DataViewer, they will be in US standard...
