u7194 calibration help 06montess/mekel
uknowmehfo
Post by uknowmehfo »
i have been a member of these forums forever and gotten alot of information. I have 4 predators and work great. i bought a truck back in 2010 and programmer but sold the truck and never used it. bought a 2009 5.3 silverado last week and was like i have a programmer.
I plug it in, follow the prompts and it says "Calibration not currently supported. Predator will try to save original. Then it shows numbers of pcm ect ect."
i have file i just xfered to my laptop here at work.
not sure what i can do with it?
i am sure you will chime in monte/mekel
i know it needs an update.
i have tool right here with me as well
serial : if needed can provide
part u7194u7149
version: v9r28
hardware: univ_rev2
bus:can
born: 12/28/2011 22944
PCM_630501651221.grg
(60.34 KiB) Downloaded 387 times
Re: u7194 calibration help 06montess/mekel
well, restore the backup to the truck then update to this version, hopefully its been added here, if not you'll need a newer tool.
u7194-9r31.crom
(1.82 MiB) Downloaded 370 times
plus keep in mind, with that predator, you can not adjust the transmission tune at all.. so can't change shift points, shift firmness, how quick it shifts, torque management, etc.. can't do anything for the tranny with a predator..
you'd need an inTune i2 or a Trinity to be able to tune the tranny..
uknowmehfo
sweet titties.... connect and i was able to change tires and turn off dod all i was looking for. i threw on just 1st one i seen was MMPG booster doubt it does to much for this bad boy but still connected and was able to work.
thanks for information/ help guys.
