This first image is when it is attached to my PC and after it 'says' it has updated
The second image is what the firmware says when I connect it to my vehicle
This is when I try to flash my original file back
The fourth is what it says when I try to adjust parameters or install a tune.
I get this when I click okay above.
Rinse and repeat
Unable to update/calibrate *Please help ASAP*
RealtorRod
Re: Unable to update/calibrate *Please help ASAP*
what vehicle?
please post the info.xml file from the intune drive.
RealtorRod
It is a 2014 Jeep GC 5.7L. I have attached the XML below.
RealtorRod
what started this?
did you take the truck to a dealership and then try to tune it when you got it back?
RealtorRod
I took my vehicle in for the shifter tsb. I guess they may have done something. If so, how do I fix it?
fax or email proof of the dealer flash to us then call with the tool powered up and we'll reset it.
RealtorRod
I will have to get them to send me a copy of what they did as it was a free service so I did not receive a receipt.
RealtorRod
see attached
