With this unit, can I mod the tunes it comes with? Or am I limited to modding only the stock tune or running the modded tunes as they come in the unit?
2016 F150 5.0
modding 87/91/93 canned tunes?
02 Tahoe
5.3 w/FLEX
5.3 w/FLEX
Re: modding 87/91/93 canned tunes?
we offer quite a few end user options for modifying the tunes, ours or stock, or custom tunes can be modified.
Thanks for the reply Mike.mikel wrote:we offer quite a few end user options for modifying the tunes, ours or stock, or custom tunes can be modified.
Is there a list of the mods/functions the I2020 can do with the 2016 F150 5.0 that I can acquire?
I'm a previous user of the U7194 (I think it was) and had my Tahoe running like a top!
Thank you.
02 Tahoe
5.3 w/FLEX
5.3 w/FLEX
Cooling Fan Control
Idle RPM
Top Speed Limiter
Rev Limiter
Part-Throttle Shift Points
Global Timing Adjustment
MAF Curve Adjustment
WOT Cam Adjustment vs RPM
WOT Fuel Rich/Lean Adjustment
WOT Spark Timing Advance/Retard
Idle RPM
Top Speed Limiter
Rev Limiter
So no shift firmness or torque management override?mikel wrote:Cooling Fan Control
Idle RPM
Top Speed Limiter
Rev Limiter
and umm, I am not sure the 15-16 F150 5.0 are mass air?
Thanks for your replies Mike.
02 Tahoe
5.3 w/FLEX
5.3 w/FLEX
they are not mass air, its a generic list for all supported 11-up F150
TM is reduced in the tunes.
