adjustable parameters on 2016 challenger hellcat
aw148751
Post by aw148751 »
What parameters are you supposed to be able to adjust with the i2010? I'm not seeing the fan settings.
Re: adjustable parameters on 2016 challenger hellcat
fans, rev limit, idles speed, WOT fuel, WOT timing, speed limiter, seeing those?
aw148751
Post by aw148751 »
I've got everything but the fans. I've updated the tuner but still not there. I tuned my 2015 scat pack and could adjust them but with the new car it's all there just no fan settings.
Odd, we'll look into that.
aw148751
Post by aw148751 »
Any updates guys?
sohfast94
Post by sohfast94 »
aw148751 wrote:Any updates guys?
https://www.dropbox.com/s/l6hqvzmelhczp ... l.ITF?dl=0
drop that onto the intune drive and let it load. Should be there after that.
Insert Clever comment here...
aw148751
Post by aw148751 »
No fan settings yet. I downloaded what you sent and updated my i2 and it still has everything but the fan settings. Restored the stock tune and tried it again, no change. Changed to 91 octane tune and more of the same.
sohfast94
Post by sohfast94 »
Post the info.xml file.
aw148751
Post by aw148751 »
<?xml version="1.0"?>
-<tool_info>
<registration updates="0" tool_oem="DIABLO_D" status="0" sn="14U7Z5KODI"/>
-<applications count="5">
<application rev="2r01j" name="vehicle"/>
<application rev="missing" name="updater"/>
<application rev="2r01e" name="gui"/>
<application rev="2r01c" name="installer"/>
<application rev="2r01a" name="logger"/>
</applications>
-<databases gui="2r01c" vin="2r01g" dtc="2r01a" dbnames="2r00">
<database pid="2r01cc" tune="2r01c" mfr="DCX"/>
<database pid="2r01cf" mfr="FORD"/>
<database pid="2r01ba" mfr="GM"/>
</databases>
<last-connected vin="2C3CDZC92GH217432" mfr="DCX" calid="68286870AC"/>
<last-connected calid="05035471AC"/>
-<licenses tuned="1" available="1">
<license vin="2C3CDZC92GH217432" mfr="DCX" PCM="68286870AC"/>
</licenses>
<reg reg="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"/>
</tool_info>
you do not have the uypdate loaded that he provided, please reload it, restore the stock tune then check the params again.
aw148751
Post by aw148751 »
mikel wrote:you do not have the uypdate loaded that he provided, please reload it, restore the stock tune then check the params again.
i downloaded it again. still no fan settings.
-<tool_info>
</applications>
<database pid="2r01cc" tune="2t01dl" mfr="DCX"/>
</databases>
</licenses>
<reg reg="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"/>
</tool_info>
sohfast94
Post by sohfast94 »
Can you post your actual info.xml please?
aw148751
Post by aw148751 »
sohfast94 wrote:Can you post your actual info.xml please?
I thought that was the info.xml file. Where do I get it?
he wants you to attach the actual info file, rather than the contents of the file
aw148751
Post by aw148751 »
<tool_info>...</tool_info>
