7000 & 8000 Predators
What happened to the page to get the tunes for the 7000 & 8000 Predators. I am a CMR dealer with new old stock Predators and need to program one for an 02 F150 5.4.
Can you supply a link or send me a file [email protected]. I need the program to load it too as I have a new PC since I did the last one.
Re: 7000 & 8000 Predators
the U7000 file for U7153 is here.fccustoms wrote:What happened to the page to get the tunes for the 7000 & 8000 Predators. I am a CMR dealer with new old stock Predators and need to program one for an 02 F150 5.4.
You can download dsdl to load it from downloads page on our site.
- u7153_fseries-9r04_for_eec_ready.crom
- (748.84 KiB) Downloaded 355 times
Thanks for the file and instructions. So now I dont seem to be able to get the serial to usb cable to work. If the prolific cable not compatible with 64 bit windows 10?
should work fine, try the driver from our downloads page.
I did it keeps installing it on com3 but is says driver error when I go look at it in settings
Here is what I am seeing
- IMG_2565 (1).JPG (112.38 KiB) Viewed 7803 times
what is the error in the device manager?
code 10?
code 10?
My DSDL only gives me com1 as an option. My usb to serial is very old I read on prolifics web site something about a newer chip? Any suggestions would help I have a customer who would like to pick up this predator today.
Yes it is This device cannot start (Code 10)
fix attached.fccustoms wrote:My DSDL only gives me com1 as an option. My usb to serial is very old I read on prolifics web site something about a newer chip? Any suggestions would help I have a customer who would like to pick up this predator today.
- Driver Fix.docx
- (35.9 KiB) Downloaded 315 times
I appreciate your help but the doc you sent is dated the link in #3 and the first one in #7 is broken the second link in #7 takes you to www.diablosport.com so the only one that works is taking me to the legacy connect page. That might help but not until I get the driver fixed.
use the driver here then follow the steps from the device manager:
http://installers.diablosport.com/softw ... e_1013.exe
So....just so the thread is warped up. After all the work by the Diablosport team with nothing fixing the problem, I finally went to Best Buy and picked up a new cable and it worked the first try. Same cable I have been using for years but now its in the garbage. Thanks for all the help, sorry to use so much of your time.
