For me it is not a huge deal right now. If anything I would like a tad more throttle boost lol. I will likely be getting a hemifever tune shortly so I am patient at the moment. A fix would be nice though eventually, I would like to have access to some of these features. Next time I hook the device up to the computer I will pull the file and maybe you can tweak it for me. Thanks for the help.mikel wrote:if you cant disable it, post the tunes from the tunes folder on the i2 drive and I will make a custom tune with it disabled.BlueKryptonite wrote:I am also experiencing the exact same thing. 2014 Ram 1500 5.7 8 speed
Why can't I see turn off MDS for my i2010
- BlueKryptonite
Re: Why can't I see turn off MDS for my i2010
2014 RAM 1500 5.7, 8 speed, 3:92
- BlueKryptonite
I hope this is what you are looking for lol. Thank You!mikel wrote:if you cant disable it, post the tunes from the tunes folder on the i2 drive and I will make a custom tune with it disabled.BlueKryptonite wrote:I am also experiencing the exact same thing. 2014 Ram 1500 5.7 8 speed
here you go.BlueKryptonite wrote:I hope this is what you are looking for lol. Thank You!mikel wrote:if you cant disable it, post the tunes from the tunes folder on the i2 drive and I will make a custom tune with it disabled.BlueKryptonite wrote:I am also experiencing the exact same thing. 2014 Ram 1500 5.7 8 speed
- BlueKryptonite
Hey Thanks Mikel! Sorry to sound ignorant but do I just copy and past the tune file into the tunes Folder on my inune? Thanks again.
next to the folders, in the root of the i2 drive.
- BlueKryptonite
Ok I dragged the file into the drive and I got the notification on the intune that the tune was loaded. Should be good to go! Thanks
Six month check in from my original post. Is there a fix for the issue yet?
That's funny that viagra spam responds faster than customer service!
Yes, a new update has been released that corrects this.
- BlueKryptonite
Just to follow up this I downloaded all the updates and such yesterday. I checked mine and it appears to be exactly the same. Tire size and stability control are the only options I am given.
please post the info.xml file from the i2 drive.BlueKryptonite wrote:Just to follow up this I downloaded all the updates and such yesterday. I checked mine and it appears to be exactly the same. Tire size and stability control are the only options I am given.
Hi mikel,
I am also getting the same issue. I've done the update through the web, installed the easy tune 91 octane, rebooted device went into advance tune, selected the 91 tune, modify parameters and i only see, tire size traction controll, WOT spark WOT fuel
not sure what to do from here but i've seen you ask for the xml file so here it is.
cheers
cheers
