I see the trem PID use what does it stand for?
Where or how do you data log long term and short term fuel trim. I need to see whats coming out of the motor as in some kind of 02 reads.
I's there a base timing table? the place that will give me access to adjusting the base timing.
I've read here in the forum. The MAP and Bio metric pressure sensor are the same thing? What I'm use to is the MAP tells you what your load is with the motor, and the BIO is pressure at atmosphere IE altitude and weather. Can some one tell me how this can be done with one sensor...
I need to under stand " scaling the senors. MAP and what other sensors need scaling and what numbers do you need? the max number generated by the Senor? and where do you do this scaling in the software?
That all I can think of for know and again sorry if these are relay basic, but I will not assume I know something. I've got caught by that thinking before.
K.C.
