failure to read message
KevinHezlep
Post by KevinHezlep »
every time i go to install a tune, it comes up with a "failure to initialize, or can not read parameter" message and then when i click continue it says install tune as selected. is this normal or is the tune not installing properly? thank you
Re: failure to read message
sounds like an easy tune bug, use the advanced tune menu.
KevinHezlep
which tune would i use?, the 93 octane is not listed under the advanced tune options are, modified stock, 91, 89, and mpg tune.
thank you
the first tune in the list is 93, diablo tune or perf tune depending on the application.
Tune for whatever octane is in the tank.
