Problems with update DCX
LE-RAM
Post by LE-RAM »
Hello,
I wanted to make an update to my DCX and get the following error :
"This inTunes cannot be updated until it is Registered"
although I have the device registers .
Would appreciate a response and help . Even would also be an optimum setting for operation with LPG .
best regards
Mike
My car is a 2012 Dodge RAM 5.7 Hemi LPG
Re: Problems with update DCX
save this to the intune drive to register it.
LE-RAM
Post by LE-RAM »
Hello and thank you for registering .
Now I have the next problem . After I made several updates , I have the DCX connected to the RAM and there made ​​the Calibration Update . Following the DCX announced that another Calibration Update 66123 must be made . The update program on the PC recognizes this too and invites the 1C6RD7NT0CS166123_68064942af.drg file and the DCX strikes .
Then it's over. The DCX does not process this update . I close the DCX to RAM to lead this through the first Calibration update , but cautions after that this fix is still missing.
I can not tune the RAM .
Ask for help.
preliminary Thanks
LG Mike
please post the info.xml file from the intune drive.
LE-RAM
Post by LE-RAM »
<tool_info>
<main full_version='InTune-1r04j 03/14/2016 10:51:37 AM' sw_rev='1r04j' svn='9115'/>
<registration sn='IGQR640-2' status='1'/>
<cal_id PCM='68064942AF'/>
<restore id='0' vin='1C6RD7NT0CS166123' bc='11'/>
<system_db info='1r01b' dtc='1r01a' vin='1r01g'/>
<db mfr='DCX' tune='1r01f' pid='1r01b'/>
<db mfr='FORD' tune='1r02h' pid='1r01b'/>
<db mfr='GM' tune='1r02u' pid='1r01a'/>
<license avail='1' tuned='0'/>
<unsupported calid='68064942AF' vin='1C6RD7NT0CS166123' oem='DCX'/>
<updates count='11'/>
<oem tool_oem='DIABLO'/>
<reg reg='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'/>
</tool_info>
thats not an I-1000-DCX, its a standard I-1000, it will not work on the 2012.
LE-RAM
Post by LE-RAM »
Hello,
it is NOT a standard I -1000 but a DCX , as evidenced by the photos. In addition, these DCX has exactly exactly this 2012 vehicle is already functioning. Only since the update spins around the DCX and throws the error with this synchronization update .
Can you do a reset and play the necessary updates to the new DCX not easy ? The RAM is currently with the original software . I have before you DCX-update the RAM reset.
The RAM has been approved in Germany 10/2012 . It may well be that he is Year 2011th but I know that it worked already and I've saved with this DCX the speed limiter and drove with the RAM 235kmh .
I ask for help / assistance .
best regards
Mike
Hedsic
Post by Hedsic »
Your tool type should say DIABLODCX but that one just says DIABLO, that is weird.
chanch1
Post by chanch1 »
Hello, Having the same error. Email: [email protected]
LE-RAM
Post by LE-RAM »
Hello and sorry,
I buy for my RAM for fast 1000 - Euro a tuning - tool Which Initially super work and get then an automatic update Once I can throw away the tool ???
It is and remains a DCX . Why this tool should not be a DCX now is not clear to me .
I've only done a manufacturer update .
Therefore, I also ask for HELP THE MANUFACTURER .
I AM SO GLAD THAT I MY RAM BEFORE UPDATE YET TO FACTORY SETTINGS HAVE BEEN RESET .
Greetings from Leipzig Germany
Mike
LE-RAM
Post by LE-RAM »
Hi Mike,
there is already a solution for this problem ?
best regards
Mike
LE-RAM
Post by LE-RAM »
Hello,
somehow I 'm getting disappointed . Only I get here in the forum no further help and support during the update error of my DCX and now the mail traffic is not even more answers from the support .
So a DCX is not cheap . And is made of a system update unusable. Should one after each update buy a new DCX ? Is that the meaning behind why is not helpful one ?
I'm really pissed off .
When do I get a functioning update ?
LG from LE
Mike
