List of Adjustable Parameters
Bagger97
Post by Bagger97 »
I have a 2015 Silverado and can't find a list of all the adjustments I can make. Would be nice to have a plan before connecting to OBD port.
2015 Silverado 5.3 CC
Re: List of Adjustable Parameters
select your vehcile from the drop downs on our site, then click on i2, then scroll down to see all tunes and feautres like this:
Features
Add Horsepower, Torque and Fuel Economy to your vehicle without even popping the hood!
Featuring the latest generation ARM processor. The device's display has a higher resolution screen and an exceptionally responsive touch pad.
DiabloSport's pre-loaded tunes are dyno and street tested to ensure optimal power and drivability gains. Basic installation, big power gains!
Easy tune asks you for what octane gas you want to run, if you've changed your tire size, if you want to remove the speed limiter and more. It's the perfect way to drop a tune on your ride in minutes!
Start off with DiabloSport's preset performance tunes and make changes that suit your performance needs. Adjust options like timing, fueling, idle, speed limiters, rev limiters, tire size, gear ratios and more.
The i2 retrieves diagnostic data of how your vehicle's tune is performing. Export all of your data to a PC and play it back on DiabloSport's Data Viewer logging software.
Regardless of whether you purchased an i2 for a Chrysler, Ford, or GM- you can buy an additional license to tune ANY vehicle supported by DiabloSport!
Update your i2 software on virtually any computer- Mac, Windows, Linux. Update times are faster than ever, even large updates only take about 5 minutes.
Holds up to 5 custom tunes. Use our worldwide network of CMR tuners to step above our canned tunes.
Touch Screen
Data Logging
Check Clear DTCs
5 Volt Data Logging Inputs
Accepts Custom Tunes from CMR
Performance/Diablo Tune 20HP 25TQ
87 Octane Performance Tune: 13HP 18TQ
Calibrate Speedometer for Gear Ratio
Calibrate Speedo for Tire Size
Cooling Fan Control
Fuel Rich/Lean Adjustment
Spark Timing Advance/Retard
Idle RPM
Top Speed Limiter
Rev Limiter
Disable Active Fuel Management
Bagger97
Post by Bagger97 »
Um thanks but not what I was looking for. If I select 87 octane load, what gets changed and to what. Timing change, speed limit changed to? or modify stock program changes what? None of the manuals list what you are actually changing from stock.
there are too many changes to list, but timing, fueling, throttle, shift pressures, torque managements, etc.
