Calibration update ready to install
ssteven40
Post by ssteven40 »
I just got an intune i1000 from a guy, I plugged it into my computer and it says its up to date. I plug it into my truck (2001 gmc 2500 duramax) and a message comes up that says calibration update ready to install. I hit the green arrow and is says turn key on to connect to vehicle, I turn key on and it thinks for a while then says calibration update error. it just repeats this. any help greatly appreciated
ssteven40
Re: Calibration update ready to install
Post by ssteven40 »
It's also saying in recovery mode, not sure what that is. Any ideas?
ssteven40
Post by ssteven40 »
Will this not work on my truck? Am I doing something wrong?
ssteven40
Post by ssteven40 »
Nothin?
yikes...please dont keep trying that.
Apparently this tool was used and not restored properly and its trying to load an update from other vehicle to your truck, if it is able to do it, things will not end well ;)
Please connect it to a pc and post the info.xml file from the intune drive here so we can check it out.
ssteven40
Post by ssteven40 »
Wow good to know.
I will post it up this evening,
Thank you
ssteven40
Post by ssteven40 »
hope this works.
thanks
info.xml
(2.4 KiB) Downloaded 317 times
ssteven40 wrote:hope this works.
thanks
OK, its not married, but it needs to be reset before you do anything with it.
Please give us a call when you can and have the device powered up, and tell the tech you need to reset it as you bought it used and its in calibration update recovery mode.
ssteven40
Post by ssteven40 »
Ok thank you for your time.
