speed limiter
hans
speed limiter
Post by hans »
How to shut the speed limiter off? Stang GT 2006. U 7140. When I shut it off in modify tune, its appears to come on again when I install the tune (steeda 91). :roll: Car runs great by the way.
Hans
christina
RE: speed limiter
Post by christina »
What revision of the Predator is this (top line of the main menu, above Performance Tune)? What is the calibration of your vehicle (Options/Troubleshooting/Show Calibration ID)?
And to clarify, you select the Steeda tune, modify it to turn the speed limiter off, then install it?
Christy High
lurker.
hans
RE: speed limiter
Post by hans »
To start with yr last Q: yes! and I also modified the cooling fan temp (plus 5 degrees was enough) since the cooling fan came on constantly. And that modification worked out well. But the speed limiter seems stubborn.
I have the U 7140, 8R38 revision
Stang GT with steeda CAI, Borla x-pipe with cats, plus Borla catbacks. As said : the car runs great and rev limit is set at 7000 rpm
Hans
hans
RE: speed limiter
Post by hans »
Christina or whoever, i am waiting for an answer. How to shut of the speedlimiter
Hans
christina
RE: speed limiter
Post by christina »
Hans,
Where is the speed limiter cutting off? Can you email me a copy of your Last Tune Written and I will take a look and see if I can figure out why it's not working and also send you a tune that will work.
Christy High
lurker.
hans
RE: speed limiter
Post by hans »
ok, i'll do that
Hans
Return to “Predator Ford Gas”
