Updating issues. Keeps updating and verifying no matter what
EugeneSL
Post by EugeneSL »
Removed tune [which is amazing] from my Tahoe for the airbag update. I decided I should update the tuner before reinstalling on the Tahoe. I did the update and followed the instructions. It went into loop of updating and verifying. I left it overnight and came back to it doing the same thing. I said F it and unplugged it. Now whenever I plug it into any computer it automatically starts doing updates by itself. It eventually finishes after a long period of time. However when I unplug it and plug it back into any computer it immediately starts updating again the second it gets power. Is there any way I can hard reset this thing back to factory settings and do the update process from the beginning? Any idea what could have made this react in this way?
Thanks for all the help! :drivingbad:
FWIW...
GUI: 2r01h
Installer: 2r01d
Logger: 2r01a
vehicle and updater blank
info.xml attached
Re: Updating issues. Keeps updating and verifying no matter
is there a file on the drive called group_update?
If so delete it :)
EugeneSL
Post by EugeneSL »
Success. Awesome.
So it's all good and ready to tune now?
I notice in the info file the "updater" rev is missing. That's ok? 2r01 is the latest?
Thank you very much!
Best,
Gene
p.s. anything fun happen if I change wifi from false to true? :D
nope, nothing will happen.. there's no wifi support for the tool at this point..
EugeneSL
Post by EugeneSL »
06MonteSS wrote:nope, nothing will happen.. there's no wifi support for the tool at this point..
Thank you!
And as far as the info file shows I'm all good?
I've been toying with getting a custom tune for my C7Z. I see you're a little less than an hour from me. Any way to get a dyno tune from you through the Diablo?
Best,
Gene
Thank you!
Best,
Gene
I'm in CT.. and no, no dyno shop here, my custom tuning - DiabLew Tune - is my own home business.. everything is done via email with tune files, data logs, etc...
Return to “Ignition updater”
