An unexpected error occurred: Tool OEM is missing
e_clayborn
Post by e_clayborn »
I have an I-1000 that I am trying to get updated to work on my 2015 GMC Sierra. When I try and run the auto update I get the following message An unexpected error occurred: Tool OEM is missing
I attached my info file. What do I do from here?
info.xml
(435 Bytes) Downloaded 373 times
Re: An unexpected error occurred: Tool OEM is missing
Man this is way out of date :)
Its going to take some work to get it qwhere it needs to be.
Load this to the intune drive and let it import the file then let us kn ow wen thats done.
_registration.itf
(387 Bytes) Downloaded 384 times
e_clayborn
Ok, I loaded that file. Latest info file is attached.
What is the next step.
Thank you
info.xml
(435 Bytes) Downloaded 353 times
e_clayborn
I'm still getting the error when trying to update. What is the next step? I attached my latest info file on the previous comment.
load this ot the i2 drive first.
intune-1r01i.itf
(1.48 MiB) Downloaded 482 times
After it loads the 1r01i file, save this to the intune drive, and let it import.
intune-1r03y.itf
(1.82 MiB) Downloaded 437 times
Once it has loaded 1r03y, save this to the intune, let it import and reboot, then it should auto run the intune updater. Let that update the device, then it should be good to go.
cdrom-1r01w.itf
(3.97 MiB) Downloaded 426 times
e_clayborn
Auto Updated all he way through but when I hook it up to the truck it gives a VIN database error...
What now?
its missing the VIN DB, needs to be updated still.
