So I have the DCX i-1000 for my grand cherokee. With the new pickup I have have the PCM added.
1. When I go for service, I must switch out the PCM. Is the DiabloPCM never going to get updated then and only the OEM gets updated when I go for service?
2. The tires settings on my DCX i-1000 never worked. I would try to set it and it would error. Does the tire adjustment work on the i2 for the Rams?
3. Can MDS (AFM) be turned off on these for my truck?
4. Is there a difference between the i2 and the more expensive tuner in performance or adjustable parameters or is it strictly visual?
Thanks in advance.
2016 Ram 1500 5.7 8 Spd Questions
Re: 2016 Ram 1500 5.7 8 Spd Questions
the i-1000-dcx will not work for the 16 Ram, you'll need i2 or trinity.
Give us a call and we can make you a nice upgrade offer.
RealtorRod
Thanks Mike,mikel wrote:the i-1000-dcx will not work for the 16 Ram, you'll need i2 or trinity.
Can you answer my few questions there as well?
1. When I go for service, I must switch out the PCM. Is the DiabloPCM never going to get updated then and only the OEM gets updated when I go for service? Correct.RealtorRod wrote:So I have the DCX i-1000 for my grand cherokee. With the new pickup I have have the PCM added.
Thanks in advance.
2. The tires settings on my DCX i-1000 never worked. I would try to set it and it would error. Does the tire adjustment work on the i2 for the Rams? Yes it works.
3. Can MDS (AFM) be turned off on these for my truck? Yes it can.
4. Is there a difference between the i2 and the more expensive tuner in performance or adjustable parameters or is it strictly visual? I2 has multi license capability, and is much faster than i1000.
