8 Speed Transmission
Re: 8 Speed Transmission
Lars, please give us a call and we'll swap that tool out for you, its missing a file needed to update properly.
Hi Mike,
thanks for this offer. I appreciate that. But I would like to mention that I come from Germany. It will be very complex and expensive to change the device.
If there is still any other idea to fix then we should try it before.
Lars
Lars
please try saving the attached file to the i2 drive and see if the device will import it.Lars wrote:I can do what I want. The device does no update.
Is there a possibility to reset the i2?
nitrodave88
does anyone know if this helps the toqure converter shudder these 8 speeds have? or at least some of them have and mine is one lol
Unfortunately Not.mikel wrote:please try saving the attached file to the i2 drive and see if the device will import it.
Mine had the shudder and was replaced under warranty. That's the only repair. Other than dealerships doing a double flush to try and make it go away.nitrodave88 wrote:does anyone know if this helps the toqure converter shudder these 8 speeds have? or at least some of them have and mine is one lol
nitrodave88
toneyjay did they do just converter or it and trans?
Just the Converternitrodave88 wrote:toneyjay did they do just converter or it and trans?
toneyjay wrote:Just the Converternitrodave88 wrote:toneyjay did they do just converter or it and trans?
any chance you're located in NJ? I'm looking for a lace that has done the TC replace before...
LOL not quite. SC.
Are there any other ideas besides the exchange of the device?mikel wrote:please try saving the attached file to the i2 drive and see if the device will import it.Lars wrote:I can do what I want. The device does no update.
Lars
it will need to be swapped out, give us a call and we can get it set up.
nitrodave88
i sent in my tcm file and I haven't heard anything back and idea when might be a fix for these certain tcm
when did you send in the file?nitrodave88 wrote:i sent in my tcm file and I haven't heard anything back and idea when might be a fix for these certain tcm
nitrodave88
I sent it over a week ago here it is again
