i2 WiFi... works like a charm
wehowardjr
Post by wehowardjr »
Received the ferrite beads 1/2 hour ago and installed them onto the cables. Went out to my truck and my i2 connected instantly to my home WiFi. Nice feature....
Thank You
Re: i2 WiFi... works like a charm
gad to hear it, enjoy!
WingsAA
Post by WingsAA »
Strange occurrence... when updating via WiFi it updates reboots and every time I check for updates it say updates are available and ask if I want to download and install. I've done this four times now... can't believe there are that many updates. Seems like it's pushing the same update over and over.
The one odd thing is the percentage progress meter goes backwards a couple times and then it finishes and say updates successfully installed and says I can click OK to reboot the device.
this should be cleared up, it was a bug on our end.
WingsAA
Post by WingsAA »
mikel wrote:this should be cleared up, it was a bug on our end.
Thanks for confirming.
ThomasTedsmall
i2 WiFi works like a charm
Post by ThomasTedsmall »
That looks nice. I like the low sleek look of it. By the sounds of it they have a winner on their hands. Is this out now ?
Jmaes
vig
Post by vig »
is this for everyone now? or just beta testers? My wifi setup on the I2 is still grayed out
update, then open the new updater and it will prompt you to register for wifi.
vig
Post by vig »
:edit:
I see you have to submit a wifi registration to get the ferrets as mentioned above, but i fill in all the boxes and accept the bcc regulations box but the serial number box is not letting me input a serial number. Any help is appreciated. I feel like a computer illiterate with all the issues I'm having with this I2. :normal: :punisher:
post the info.xml file from your i2 drive please.
vig
Post by vig »
thank you
are you entering this as the serial?
14U7ZCHAWD
vig
Post by vig »
mikel wrote:are you entering this as the serial?
14U7ZCHAWD
its not letting me enter a serial at all. The option is grayed out on the application.
maybe you need to enter values in the other boxes first?
vig
Post by vig »
mikel wrote:maybe you need to enter values in the other boxes first?
edit: got it guys, thank you!!
