PCM might need update but the InTune says no updates
tvalentino3
Post by tvalentino3 »
I restored factory settings to my 14 Ram before taking it in for service. After getting it back (and even putting drive cycles on it) the programmer say it might need a PCM calibration update and to plug it in to my PC. When I plug it in there are no updates available. current version is 1t04j in the info tab? :crashing: :crashing: :crashing:
<tool_info>
<main full_version="InTune-1r04j 03/14/2016 10:51:37 AM" sw_rev="1r04j" svn="9115"/>
<registration sn="J2EYK65-4" status="0"/>
<cal_id PCM="68153771AK"/>
<restore id="0" vin="3C6JR7DTXEG238228" bc="5"/>
<system_db info="1r01b" dtc="1r01a" vin="1r01g"/>
<db mfr="DCX" tune="1r01v" pid="1r01b"/>
<db mfr="FORD" pid="1r01b"/>
<db mfr="GM" pid="1r01a"/>
<license avail="1" tuned="0"/>
<unsupported calid="68153771AK" vin="3C6JR7DTXEG238228" oem="DCX"/>
<updates count="3"/>
<oem tool_oem="DIABLODCX"/>
<reg
tvalentino3
Re: PCM might need update but the InTune says no updates
info file should be in the attchment
tvalentino3 wrote:info file should be in the attchment
it downloaded the update for me, copy this to the i2 drive and it will import it then you can load the update then tune the vehicle.
