Hello,
My InTune1000 will not communicate with my truck.
I had issues in the past with this tuner crashing. I finally just had the tuner flashed/restored with help of one of your techs. The tuner now works and is no longer in Recovery Mode, as it was before. I plugged it into my computer, and it downloaded updates, and seemed to be working like normal again.
HOWEVER, now when I plug it into my 05 Dodge Ram 1500 5.7 Hemi truck, the tuner powers up, like normal, and when I get to the screen to Turn On Ignition...it never acknowledges that I did turn the key, and then after a few minutes, the tuner goes to the main menu. It will not check communicate at all with my truck.
Now, I have had to replace the BCM and the Gauge cluster a few months back.
Please help
Will NOT communicate with my truck
- speedbee29
Re: Will NOT communicate with my truck
post the info.xml file from the intune drive please.
- speedbee29
I attached the XML file
- info.xml
- (1.07 KiB) Downloaded 195 times
seems there is a communication issue in the truck, did you have the nee modules programmed by a dealer?
- speedbee29
No, I did not...Does that need to happen?
I bought the BCM and Speedo from wrecking yard, everything works except this issue.
thats likely going to be the fix.
