PCM Calibration Needed
scott57rt
Post by scott57rt »
I'm helping a friend upload a diablotune to his vehicle for the first time. We are unable to upload the tune. It looks like we are having a similar problem as some others on here. The tuner says the car is unsupported and needs a PCM update. We have updated the tuner software using IntuneUpdater2.exe, but it still gives the same error. The car is 2012 Charger SuperBee. I can provide the info.xml if needed.
SCOTT57RT - 2007 RT Charger 5.7L - Black Crystal Pearl
Procharged with Inertia Cam
Re: PCM Calibration Needed
please post the info.xml file here.
scott57rt
Post by scott57rt »
see attached
please run the updater again now and it will download the file you need.
scott57rt
Post by scott57rt »
Thanks Mike. It looks like the intune was able to download a new update. I'm not sure I understand all the magic you did behind the scenes, but it looks like it worked. I'll let you know if we have any problems with the pcm update on the car.
