Intune rebooted when restoring backup
WingsAA
Post by WingsAA »
I was restoring the factory backup to my 16 yukon xl denali and after it restored the ecm the intune screen went black and it rebooted after the final key cycle for the ecm and before restoring the tcm. When it came back on, it said the device was in restore mode click yes to continue with restore or no to go to the support menu. I clicked yes and it proceeded to restore the stock tcm tune and I did the key cycles and it said all was well and the device can be unplugged or rebooted.
Needless to say I got a little nervous when the intune rebooted between the ecm and tcm restore with no warning. But I played along and it seemed to work out. Is this normal process now that the 8spd tcm tuning is supported?
Re: Intune rebooted when restoring backup
No, not normal for sure, must have been something that interrupted the flash process.
WingsAA
Post by WingsAA »
Awesome... that's what I was afraid of. Not sure what caused it as the ignition was still on.
First time I encountered that happenning.
White Denali
Post by White Denali »
Well I have a 2016 Denali 8 speed and did same thing. But I was loading a 87 tune and tcm tune and it did that then when came back on it said returning to stock and it did without problems then I had to start over and load the 87 tune which it work this time but not sure what happen?
