PCM_UNKNOWN
jamesacastro
PCM_UNKNOWN
Post by jamesacastro »
Went in for my oil / tire rotation and an update for intellilink. I let them know the trans is still acting up so they performed a transmission control module reprogram with SPS. Now I get the PCM_UNKNOWN when trying to program. Attached is the PCM_UNKNOWN file. Do you need anything else from me?
Thank you
Jimmy
Re: PCM_UNKNOWN
A copy of the info.xml file from the i2 drive would be appreciated.
Thakns
jamesacastro
Re: PCM_UNKNOWN
info.xml, tcm and pcm attached
jamesacastro
Re: PCM_UNKNOWN
Thank you for the update. Worked like a charm.
Quick question ~ Is there any reason why it needed the update? Did the dealer replace my TCM / ECM?
Re: PCM_UNKNOWN
you just had a newer cal than what we had in release.
