2016 Jeep JK W/RIPP SC and I2
RugbyRef
Post by RugbyRef »
Just purchased a 2016 JK Rubicon w/dealer installed RIPP SC. I also received an I2 with the RIPP tune installed. However...I was told by the dealer if I change the type of gas in the JK (Octane 89, 91, or 93), I would need to update the PCM using the I2 by selecting the correct octane. Okay...so far, so good! Plugged in the I2 and it powered up normally. After I selected "Yes" to the statement about the use, a screen appeared that showed the following:
"Easy Tune"
"Advanced Tune" (I think it said that)
There was a third selection, but I can't remember what it was. Anyway...the "Easy Tune" is not selectable (greyed-out). In the "Advanced Tune" I can only select things like axle ratio, TPMS, etc.
My question's are: How (or where) do I adjust the octane set points? Why is "Easy Tune" greyed-out and not selectable?
Thanks in advance!
Tim
Re: 2016 Jeep JK W/RIPP SC and I2
there are no different octane tunes for the RIPP supercharger tool, just the tune for the supercharger. Id check with RIPP for recommended octane requirements.
RugbyRef
Post by RugbyRef »
Thanks for the quick reply Mike! Can I assume then that the RIPP tune is causing the "Easy Tune" to be locked out (greyed-out)?
yes.. the tool will not have the regular diablosport tunes on it, because it is specific for RIPP and their supercharger setup, so it will only have the RIPP tune on it, that's it...
RugbyRef
Post by RugbyRef »
Thanks folks! As usual...right on the spot with an answer!
