6.4L Dodge Challenger Wouldn't Start up
djpiezo
Post by djpiezo »
I have a 2014 Dodge challenger SRT392 and after installing the Diablo tune 93
Car wouldn't start up after several tries.Loaded original factory tune back on the car it fired up
What gives?
Re: 6.4L Dodge Challenger Wouldn't Start up
no crank, no start?
Thats really odd, did you use the puch button to load the tune or removed it and used the key?
If you used the button, thats likely the issue, try again with the actual key.
djpiezo
Post by djpiezo »
sorry for the late reply mike i was using the push button and panicked i will go out and try it again
djpiezo
Post by djpiezo »
now its saying that i need a calibration update? back to the computer i go
djpiezo
Post by djpiezo »
now upadating
djpiezo
Post by djpiezo »
Stage 1 loading....now applying stage 1
djpiezo
Post by djpiezo »
djpiezo wrote:Stage 1 loading....now applying stage 1
Stage 2 damn this takes forever!
djpiezo
Post by djpiezo »
Building diablosport tune
djpiezo
Post by djpiezo »
djpiezo wrote:Building diablosport tune
Long wait but almost done
djpiezo
Post by djpiezo »
Finished but same results no start
can you give us a call with the tool powered up in the car?
djpiezo
Post by djpiezo »
Sorry for the late post but I've found out that I can't touch the rev limiter in neutral setttings
djpiezo wrote:Sorry for the late post but I've found out that I can't touch the rev limiter in neutral setttings
yeah, that may be an issue, skip them for now, theres really no good reason to change that anyhow :)
