6.4L Dodge Challenger Wouldn't Start up
I have a 2014 Dodge challenger SRT392 and after installing the Diablo tune 93
Car wouldn't start up after several tries.Loaded original factory tune back on the car it fired up
What gives?
What gives?
Re: 6.4L Dodge Challenger Wouldn't Start up
no crank, no start?
Thats really odd, did you use the puch button to load the tune or removed it and used the key?
If you used the button, thats likely the issue, try again with the actual key.
sorry for the late reply mike i was using the push button and panicked i will go out and try it again
now its saying that i need a calibration update? back to the computer i go
now upadating
Stage 1 loading....now applying stage 1
Stage 2 damn this takes forever!djpiezo wrote:Stage 1 loading....now applying stage 1
Building diablosport tune
djpiezo wrote:Building diablosport tune
Long wait but almost done
Finished but same results no start
can you give us a call with the tool powered up in the car?
Sorry for the late post but I've found out that I can't touch the rev limiter in neutral setttings
yeah, that may be an issue, skip them for now, theres really no good reason to change that anyhowdjpiezo wrote:Sorry for the late post but I've found out that I can't touch the rev limiter in neutral setttings
